Configures the BGP retry timer of the specified peer group.
| peer-group-name | Specifies a peer group. |
| connect-retry | Specifies to configure the time interval between attempts to establish a TCP connection to a configured peer. |
| seconds | Specifies the retry time in seconds. Default is 30 seconds. |
This feature is disabled by default.
The following command configures the BGP peer group "internal" retry timer to 120 seconds:
configure bgp peer-group internal connect-retry 120
This command was first available in ExtremeXOS 31.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
